For a range of images getting values as continuous in attribute table but need to create column of the image sensing date and write values in that column
  • Oct 7, 2019 2:32 PM UTC
  • 81 views
I have downloaded a date range images of sentinel 2, performed clipping (polygon) and calculated NDVI. Then I have converted raster to point and extracted each pixel values parallely extracted coordinates from coordinate extracter. So in attribute table I have date for each pixel, NDVI value of each pixel , latitude and longitude of each pixel. But I need attribute table structure as Latitude, Longitude and each day Ndvi values. So each date of image generated should create a column and writes NDVI values for same lat longs.
gio
Forum|alt.badge.img+15
  • Oct 9, 2019 1:58 PM UTC
@sandyson558
Sounds like you need to partitionize (and maybe transpose) your data.
Do you have a sample of the data? So we know how the input looks like.
jdh
Forum|alt.badge.img+41
  • Oct 9, 2019 2:35 PM UTC
I would use an attributeCreator to create an new attribute with the name coming from the date and the value coming from the NDVI, and then use an Aggregator with a group-by on lat/long and merge attributes set, followed by a schemaSetter and then a dynamic writer.
