FMEUniversalReader from a file like object?
  • Aug 25, 2025 10:52 AM UTC
  • 36 views
itsmatt
Forum|alt.badge.img+48
I have a texture embedded in a binary file. I’m trying to extract the textures and apply them to the geometry I’m loading.
I figured the easiest way to do this is to read the textures in with the FMEUniversalReader. I quickly found out that I need to pass the input file as a string (filename). Ideally I’d pass this as just a BytesIO object as the library I’m working with already loads the data as a PIL object.
At this point I don’r really see a way around writing out the textures to disk and then reading them again with FME.
Any other ideas?
itsmatt
  • Aug 25, 2025 1:44 PM UTC
ok weeeell it seems like I can’t set an FME Raster as a texture with FME objects anyway.
So this question is irrelevant
