FMEFlowJobSubmitter 'Failure when receiving data from the peer'
  • Sep 19, 2024 9:16 PM UTC
  • 253 views
taylordowns
Forum|alt.badge.img+4
Hello everyone,
I am reaching out because I have run into a problem recently and searched through previous thread and couldn’t quite find my issue with a solution.
I am running into a hang up when I run a workspace that triggers an additional workspace through FMEFlow using FMEFlowJobSubmitter. I will paste an example of what the log looks like.
FMEFlowJobSubmitter: https://your.specific. - Submitting a request to run workspace 'Your-Workspace' in repository 'YourRepository'…
FMEFlowJobSubmitter: https://your.specific - Failed to submit request to run workspace ''Your-Workspace'' in repository 'YourRepository'
FMEFlowJobSubmitter - 'Failure when receiving data from the peer'
My workflow is submitting around 70 jobs so after this error occurs around 15 times the error switches to:
Error: Failed to update access token.
FME Flow error: `FME Flow error: `929026:Error: Connection reset''
FMEFlowJobSubmitter: Reason - 'Failed to login'
After this cycles through and I receive this error numerous times the job submitter starts working right and the remaining jobs are sent through and executed.
The team I am apart of just upgraded this specific server from 2023.1 to 2024.1. NOTE: There are two engines that are configured to load balance on this specific server.
I am also going to submit a trouble ticket for this case, so I will keep this thread updated with what the root cause and fix was.
lazarlubomir
Forum|alt.badge.img+11
  • Feb 10, 2025 11:54 AM UTC
Hi ​@taylordowns and everyone,
do you have any solution for that issue? I have got the same trouble… :-(
taylordowns
  • Feb 10, 2025 5:15 PM UTC
Sadly there was no fix that my team or support was able to find. What I did was moved the workspaces that run the jobsubmitter into the automations and have them connected that way, instead of with the jobsubmitter. I tried multiple different solutions but none worked, from adding a http caller to trying to embed the connection, I even ended up working with my company’s server team to ensure that there were no ports being blocked. I know this is probably not the answer you were looking to hear but don’t be like me and spend months looking for the answer just to come up blank.
