FME2015 with 2014 mapping
andr__d
Forum|alt.badge.img+5
Hi All,
I have upgraded to FME 2015.0, and ran a mapping previously created with FME2014.
It went OK (successful) but now at the biginning of the translation It's scanning through all possible readers and generates me a log file of more than 100 MB.
In my mapping, I only have 2 GEODATABASE_SDE, 1 GEODATABASE_FILE and 1 XLS_ADO readers.
Why it has to scan all possible readers ? see attached screenshoot.
Thanks
André
Best answer by endest
1. Check your System Variable of PATH, include right FME 2015 folder, and make sure it is before other editions of FME
2. Check you ArcGIS DataInterop module, try to re-extend/not extend it with FME Integration Console. Or reinstall/uninstall it.
I encountered this situation before, but really forgot how to solve...
  • March 11, 2015
that is indeed weird, you should probably report it to Safe support.
What happens if you copy-paste the workspace contents into a new, blank workspace?
David
andr__d
  • March 11, 2015
David,
I have tried to do a copy/paste of my workspace into a blank workspace. But I still have the full scan of readers.
André
endest
  • March 12, 2015
endest
  • March 12, 2015
Put your PATH of FME 2015 infront of ESRI path, too.
andr__d
  • March 12, 2015
FME was not extending my ArcGIS 10.3 DI. So I ran the "FME Integration Console" to extend it and it seems to have solved the problem.
I tried also to revert back to not extend, and the problem is back. So ArcGIS 10.3 needs to be extend by FME.
Thanks a lot.
