FME Server - Wrong status message ?
  • Jan 3, 2019 10:04 PM UTC
  • 7 replies
  • 132 views
philippeb
Forum|alt.badge.img+23
Hello there!
Into FME Server 2017.1 I have some process failing for some reasons and I get the error into the log.
But when I look at the process status, it's Completed. Then, I don't get any notfications alerting me about this.
Shouldn't I receive a Failure message instead?
i could put an Emailer into my workbench, yeah, I know, but I would prefer the FME Server notification.
Into FME Desktop I get the Failure message though.
2019-01-03 17:03:36| 203.7| Â 0.0|ERROR |A fatal error has occurred. Check the logfile above for details
thanks
Best answer by erik_jan
I agree this looks like it should be a failure.
To force the ERROR you could add Terminator transformers on the Rejected ports of the critical transformers (in this example the HTTPCaller).
laurawatsafe
Forum|alt.badge.img+14
Hi @philippeb, looks like the images you added to your question have gone missing. Would you mind uploading them again? I certainly would have expected your workspace to finish with a Failed status if it finished with an error on FME Server.
  • Jan 4, 2019 8:28 AM UTC
Hi Laura, seems there's a lot of issues with missing inline images after the forum upgrade. Are you guys looking into it?
philippeb
  • Jan 4, 2019 1:21 PM UTC
Images have been reuploaded... 2/3 not really important though :P
philippeb
  • Jan 4, 2019 1:22 PM UTC
Images are always working on Chrome though, which I'm using.
It's on FF and IE it seems problematic.
erik_jan
Forum|alt.badge.img+26
  • Jan 4, 2019 3:02 PM UTC
philippeb
  • Jan 7, 2019 8:36 PM UTC
That's a good idea. It works.
Very curious though, I would like to understand why I don't get an error.
So I've done a simple test into a new workbench :
Added a Creator connected to a HTTPCaller (request URL https://googlee.com)
I get an error in Inspector but not in FME Server, I still get the Completed status.
Even with this error...
I attached the FMW to this post.
Do you have the same error on your side?
thanks.
testhttpcaller.fmw
thanks.
testhttpcaller.fmw
Hi @philippeb,
In your .fmw it looks like you have the Rejected Feature Handling parameter set to 'Continue Translation'. If you want the job to fail if a feature passes through the rejected port you will need to change this to equal 'Terminate Translation'.
Please note it looks like there was an issue with this in 2017.1: https://knowledge.safe.com/questions/65274/rejected-feature-handling-on-fme-serverf.html so you may want to consider upgrading to the latest version of FME Server or using the Terminator as erik_jan suggested.
