FME Server Locale Setting
  • Feb 12, 2020 12:19 PM UTC
  • 173 views
roberto
Hello,
we have some trouble running FME Server (2017) workbenches. Italian characters are interpreted using Server system configuration instead of the italian one. Is it enough to include in the "environment" section of the fmeCommonConfig.txt file the LOCALE=it_IT ? Other configuration needed?
Thanks
Roberto
Best answer by itsmatt
I think it will depend on where the problem is taking place. If the issue is when reading or writing data then you might/should be able to configure the reader/writer to interpret the data as whatever encoding system you want. This can be set for example in the shape reader and CSV reader. If you don't specify the encoding the it will use the system encodingby default.
I'm not sure what that config file local setting defines but it might help. I suspect not with the way the workspaces are run though.
itsmatt
Forum|alt.badge.img+48
  • Feb 12, 2020 1:45 PM UTC
roberto
  • Feb 12, 2020 2:00 PM UTC
Hi @virtualcitymatt. The error happens in an AttributeCreator where "Società" is converted into
"SocietÃ".
roberto
  • Feb 12, 2020 2:51 PM UTC
Hello. Sorry for the post. It seems that the error is not in the transformer but in the Oracle query that populate one of the variable that are concatenate in the AttributeCreator. :-(
itsmatt
  • Feb 12, 2020 3:02 PM UTC
Interesting - so your query to oracle has a ' à ' in it? Are you able to see how the query looks on the Oracle side? Is FME sending the wrong thing? Or is FME interpreting the result incorrectly?
