FME Server Error Submitting job
  • October 25, 2018
  • 21 views
sunsilk11
After setting up HTTPS, I am getting 'Error Submitting job' message. The FME Engine log contains: FME Engine failed to register with FME Server 'localhost' on port 7070. Maximum number of allowable FME Engines reached
In the list of engines, there is only 1 engine.
I have followed the following steps and the certificate generated looks fine i.e. no errors on the browser.
http://docs.safe.com/fme/html/FME_Server_Documentation/Content/AdminGuide/configuring_for_https.htm
Any suggestions ?
Best answer by hollyatsafe
Hi @sunsilk11,
Have you seen our troubleshooting guide: https://knowledge.safe.com/articles/55057/fme-server-troubleshooting-submitting-a-job-in-fme.html and additionally https://knowledge.safe.com/articles/49624/fme-server-and-https-troubleshooting-guide.html there are a few suggestions on here to check which I believe might help solve your problem.
  • October 25, 2018
Hi @sunsilk11,
