FME Server 2019.1 does not honor a predefined coordinate system
  • Apr 27, 2020 2:44 PM UTC
  • 82 views
philll
Prior in FME Server 2016.1, CANA83-10TM115-EAP is recognized by FME SVR.
Predefined coordinate system `CANA83-10TM115-EAP' (Alberta NAD83; 115 deg West, positive easting coordinates) matches dataset coordinate system
 Now in FME Server 2019.1,  here is the log:
Predefined coordinate system `10TMAEPFOREST_83' () matches dataset coordinate syst
Which is not the one set in the submitted gdb.
This is specific to FME Server, when running locally, CANA83-10TM115-EAP is set correctly within FME properties.
This is not a custom coordinate system so it should not be added to the Engine/CoordinateSystems repository according to the documentation
Any thoughts anyone? tks
daveatsafe
Forum|alt.badge.img+24
  • Apr 27, 2020 5:20 PM UTC
Hi @philll,
FME reads the Esri WKT coordinate system from the GDB and maps it to an FME coordinate system upon reading the data. It appears that your FME Server may have a user coordinate system defined that maps to the same WKT, using an .db exception file. In this case, FME will use the user coordinate system over the standard ones.
Please check your FME Server Resources/Engine/CoordinateSystemExceptions folder for any .db files that might map the GDB coordinate system to 10TMAEPFOREST_83.
philll
  • Apr 28, 2020 6:13 PM UTC
Hi @daveatsafe
thanks for your answer!
Your answer makes sense because this coordinate system 10TMAEPFOREST_83 is not listed in the FME coordinate system gallery (either FME 2016 or 2019 (we are upgrading solution from 2016 to 2019))
However there is no .db files under CoordinateSystemExceptions or under others Engine sub-folders neither in FME Server 2016
Do you see any other way FME would use a .db file or via other exceptions file?
we are using Microsoft SQL Server 2016.
