FME Parameter in SQLCreator
  • Dec 14, 2018 4:54 PM UTC
  • 85 views
sunsilk11
Hi I am trying to run an SQL to select records in past 10 mins from Oracle
I have tried various methods in my sql, but none seem to work
select * from table name where updatedtime >= sysdate - interval '10' minute
select * from table name where updatedtime >= to_char(sysdate - (10/24/60), 'DD-MON-YYYY HH24:MI:SS')
I am thinking of setting a parameter to the required datetime and use it in SQL Server
Couple of queries:
1) Is startup script best place to create this parameter
2) Will SQLCreator query work with a parameter
e.g. select * from table name where updatedtime >= to_timestamp(fmeparameter, 'DD-MON-YYYY HH24:MI:SS')
where fmeparameter ='14-DEC-2018 14:00:00'
Forum|alt.badge.img+54
  • Dec 14, 2018 5:00 PM UTC
For last 10 mins in an oracle query you would normally use the folllowing.
sysdate - (10/1440)
is there a reason you don't want to use this?
sunsilk11
  • Dec 14, 2018 5:10 PM UTC
sysdate - (10/1440)
No, I would definitely use this. But it doesn't work when used in my sql, hence looking for a workaround with a date string which works in the same sql
  • Dec 17, 2018 8:25 AM UTC
I think the bigger question is why this doesn't work in your SQL, in my opinion there's no obvious reason for it not to work. Do you get any error messages?
  • Dec 17, 2018 9:00 AM UTC
Try the following, notice that you shouldn't convert the result back to a string before comparison:
select * from table_name
where updatedtime >= sysdate - (10/1440)
