FME orchestrator
  • September 6, 2018
  • 5 replies
  • 72 views
What does the term "FME orchestrator" mean?
jdh
Forum|alt.badge.img+40
  • September 6, 2018
Data orchestration is the process of integrating two or more applications and/or services together to automate a process.
I presume FME orchestrator means the FME (Server) is the tool being used for the integration, though I would have to see the words in context to be certain.
  • September 6, 2018
Does this image provide context?
jdh
  • September 6, 2018
I suspect each orchestrator is the set of workspaces/subscriptions/notifications/connections etc required to process the model.
  • September 7, 2018
Looking at the slide it's most probably not something coming from Safe, and I can't remember ever seeing the term "FME Orchestrator" being used in official FME marketing. So my reply would be that you'd have to ask the author of the slides about the exact meaning.
That said, I completely agree with @jdh on the interpretation.
fmelizard
Forum|alt.badge.img+21
  • September 14, 2018
Yep, we've never used that term ourselves...
