FME not recognizing geometry
rishi1804
Forum|alt.badge.img+4
I have a dgn Model and it’s meshed there are some mesh elements in the model but FME is not recognizing them. AppearanceRemover is rejecting them, Geometry FIlter is returning them as null geometry. These elements are visible in microstation and looking absolutely fine.
MISSING_GEOMETRY_APPEARANCE  This the rejection code from APpearnce Remover and if I skip Appearnce Remover and pass it to geometry filter it returns the featurs as Null.
virtualcitymatt
Forum|alt.badge.img+36
When reading the DGN file are there any messages/warnings about skipped features in the log file? And are you using the V7 of V8 of the reader. The doc says that only v8 supports meshes.
rishi1804
  • May 21, 2024
I am using V8 of the reader, The logs are looking problematic but I am not able to understand exactly what’s the issue
I have attached the logs here, Please take a look
