fme fills polygons and circles
  • May 3, 2019 11:40 AM UTC
  • 126 views
f.kemminje
Forum|alt.badge.img+11
I am reading Autocad blocks and writing to PNG format(raster). In the reader itself I am dropping the blocks, and using imagerasteriser transformer and writing to png. But the problem is if the input feature contains polygons or circles , it comes as filled in png output. Actually its not filled element in Autocad?
I can I overcome this? or any workaround? (intersector is very costly)
Forum|alt.badge.img+63
Couple of things you can try:
If they are areas but not filled, use the FeatureColorSetter to assign a fill color.
If they are not areas you can use the AreaBuilder to create areas out of it (but I suspect that in terms of processing it will be a big impact just like the Intersector) or maybe the MapnikRasterizer instead of the ImageRasterizer as it gives you a bit more control.
f.kemminje
  • May 6, 2019 6:30 AM UTC
@redgeographics, i dont need fill color, i need without fill
Ah, I misread your post. Maybe if you try forcing everything to lines with the GeometryCoercer?
