FME Engine is shutting down and Process Engine2 ends unexpectedly while running a scheduled task. License is being borrowed from another license server.
The issue is intermittent but is being observed very often. When we login to FME server then it gives error "No FME Engines are available to this FME Server." The FME Engines are available once we restart the FME server service but a permanent fix is required for this issue as it hinders the regular business process. We are using FME Server 2012 SP1.
