FME Desktop 2022: Polygons fail to be saved in esri geodatabase polygon feature class,
  • Mar 2, 2022 7:33 PM UTC
  • 123 views
jamal
Forum|alt.badge.img+5
In the screenshot below, and the attached data and workbench, I couldn’t figure out why polygons fail to be stored in esri geodatabase polygon feature class
Clip_146
Best answer by daveatsafe
Thank you for the help.
How about the “aggregate”? can it be polyline, polygon or point?
Clip_150
In FME, aggregates can contain mixed geometry, but only aggregates that have the same geometry can be written to Geodatabase. If you set Homogenize Collections to Yes in the GeometryFilter, it will convert mixed geometry aggregates into several same geometry aggregates suitable for writing to Geodatabase.
daveatsafe
Forum|alt.badge.img+24
  • Mar 2, 2022 10:01 PM UTC
Hi @jamal​,
One of the polygons is degenerate - it contains only two unique points. The GeometryValidator corrects this to a line, even on the Failed output, so it cannot be written to the GDB polygon feature class. If you move the GeometryValidator before the GeometryFilter, this feature will be output from the Path port of the GeometryFilter.
jamal
  • Mar 3, 2022 8:58 PM UTC
Clip_150
daveatsafe
  • Mar 3, 2022 11:01 PM UTC
Clip_150
jamal
  • Mar 4, 2022 10:11 PM UTC
Thank you very much for the help. That’s great
Clip_167
