FME Cloud PDFStyler Issue
  • Aug 21, 2019 10:24 PM UTC
  • 71 views
deanhowell
Forum|alt.badge.img+24
I have created a workspace to extract data from a series of datasets based on selected land parcels.
When I run it from the desktop it works fine, the DWG file is created and a PDF of the data is also produced.
When I run it from FME Cloud Server, I get the following error around the PDFStyler.
94PDFStyler_2_CheckLineWidth (TestFactory): The clause 'TEST 1 TYPE NUM ENCODED FEATURE_TABLE_SHIM_SUPPORT Yes' within 'FACTORY_DEF * TestFactory FACTORY_NAME PDFStyler_2_CheckLineWidth INPUT FEATURE_TYPE FeatureWriter_public.ParcelCadastreCombined TEST 1 TYPE NUM ENCODED FEATURE_TABLE_SHIM_SUPPORT Yes OUTPUT PASSED FEATURE_TYPE __CheckLineMiterLimit__' is incorrect. TEST must look like: TEST <value> <operator> <value> [ENCODED]95The clause 'TEST 1 TYPE NUM ENCODED FEATURE_TABLE_SHIM_SUPPORT Yes' within 'FACTORY_DEF * TestFactory FACTORY_NAME PDFStyler_2_CheckLineWidth INPUT FEATURE_TYPE FeatureWriter_public.ParcelCadastreCombined TEST 1 TYPE NUM ENCODED FEATURE_TABLE_SHIM_SUPPORT Yes OUTPUT PASSED FEATURE_TYPE __CheckLineMiterLimit__' is incorrect. TEST must look like: TEST <value> <operator> <value> [ENCODED]
Can anyone shed some light on what this error means and why it does not like it in FME Server?
laurawatsafe
Forum|alt.badge.img+14
My first thought is that this error looks a lot like a version compatibility issue. What version of FME Server is your FME Cloud instance running? Is it older than the version of Workbench used to create the workspace?
deanhowell
  • Aug 21, 2019 11:29 PM UTC
The workbench is 2019.1.0 Build 19608 and Server is Build 19260.
I will upgrade the Server build to see if that fixes the issue :)
Thanks @lauraatsafe
laurawatsafe
Thanks @lauraatsafe
No problem! Hope that fixes it!
