Fme batch deploy - mirror behavior as in FME
Hi, I'm running a simple workbench that converts a single dwg to GeoJSON. when I start the process normally in FME it works fine. But when I make a bat+tcl I see that the path to the dwg file changes and there is a "\\" missing between the folder (Linjedata) and the dwg file (T_E6SL_P00_f_C_E6-Profillinje.dwg) (AutoCAD Reader: Error opening file 'C:LinjedataT_E6SL_P00_f_C_E6-Profillinje.dwg' during version check) Is this something I can change in the tcl file? However, I got around this by putting the dwg file on C:, but then I only get a new folder with the same name as the dwg file with an empty file called "C" inside as the result, instead of a GeoJSON file. What I'm trying to achieve is just the same as when I start the workbench in FME, but run as a bat file.
Best answer by hkingsbury
When you run the workspace, the first few lines of the log will contain the command line call to run the process
hkingsbury
Forum|alt.badge.img+55
  • June 7, 2023
Thank you very much, it worked great!
