FME automation - attributes from one workspace into another?
  • Aug 9, 2023 1:18 PM UTC
  • 147 views
parke372
Forum|alt.badge.img+11
I'm really new to FME, and am a little confused about how to do something.
I have an existing automation built by an integrator that parses some emails for specific text. those are then bundled up various ways and sent out to various entities via email.
I want to also send an API request with some of that data in it - the vendor i'm sending it to doesn't support a login auth, just tokens, though so i ended up making a workspace to send the call.
However, i'm kind of confused as to how i get the outputs from the previous workspace into this one?
I see the output keys from the writer, but, I don't understand how to get those keys into the next "run a workspace"
My schema for the API looks like:
    "version": "v1",
    "alert_text": "route.Email**#.RAWMESSAGE",
    "title": "route.Email**#.AlarmName",
    "IsTicker": false,
    "lifetime": "1d",
    "computers": ["MACHINENAME","MACHINENAME"]
where route. ______ is a previous output key from the upstream workspace.
this doesn't seem to work, though.
I'm assuming i need to somehow read the output keys into features in the workspace, but i'm not really sure how?
Best answer by parke372
it looks like the part i was missing was defining those features are user attributes in the new workspace. Once I did that, i was able to map the upstream output keys to the downstream workspace action.
parke372
  • Aug 9, 2023 2:08 PM UTC
Forgot to add, when i add the "run a workspace" to the automation, i don't see the dropdown for parameters and maybe that is the issue, but i'm also not sure how to get that dropdown?
parke372
  • Aug 10, 2023 7:06 PM UTC
