FME 2020: How to get all the layers automatically selected when the dwg file is selected as a source file in the reader?
  • Nov 30, 2021 8:19 PM UTC
  • 7 replies
  • 123 views
jamal
Forum|alt.badge.img+5
I found out that each time a dwg file is selected (as per the screenshot below), the “select all” option is not checked by default.
How this option can automatically be checked as any dwg is selected as a source?
Clip_1258Clip_1259
Clip_1260
Clip_1261
Clip_1262
jamal
  • Nov 30, 2021 8:20 PM UTC
cont. (last screenshot)
Clip_1263
hkingsbury
Forum|alt.badge.img+73
  • Nov 30, 2021 8:32 PM UTC
I don't have any DWGs handy to test with. but have a look at using the FeatureReader instead of the reader. You can set it up to read all Feature Types - make sure you then set it to Single Output Port. All features will then come out the generic port. There will be no exposed attributes, so you'll need to manual set those
jamal
  • Nov 30, 2021 8:48 PM UTC
Thank you for the help. I tried it but appeared not to work with me.
I’ve attached two dwg sample files with different layers
hkingsbury
  • Nov 30, 2021 9:12 PM UTC
I've attached a workbench, seems to be working fine.
Note that this is starting to encroach on dynamic workflow principals, which are a more advanced way of working with attributes and schemas in fme
https://community.safe.com/s/article/dynamic-workflow-tutorial-introduction
Q2 reads in 1181 features across 75 feature types, R2 reads in 64 features across 4 feature types
jamal
  • Dec 3, 2021 6:50 AM UTC
Thank you for the prompt help. I got two issues:
-       I couldn’t figure out how to choose another dwg file. The “run entire workspace” just runs the model without giving first the chance to choose the dwg file
-       How to add attributes to the output?
Clip_1271
Clip_1272
Clip_1273
Clip_1274
hkingsbury
  • Dec 5, 2021 10:14 PM UTC
Clip_1271
Clip_1272
Clip_1273
Clip_1274
You'll need to set the feature reader to use a Public Parameter to store the DWG, then each time you run it, it will prompt you.
All the attributes are being read in, however they're not exposed. You'll need to expose the ones you want to deal with
jamal
  • Jan 1, 2022 7:19 AM UTC
I got two dwg files (attached), the first one is D1 that has three layers (0, P1, P2), the second one is D2 which has 4 layers (0, M1, M2, M3).
In the screenshots below, as the second dwg file is selected, the layers are not selected automatically
Which settings are needed in order to get the layers selected automatically as new dwg file is chosen?
Clip_1441
Clip_1442
Clip_1443
Clip_1444
Clip_1445
