FME 2019 Undefined Macro Error
daveapegg
Forum|alt.badge.img+4
Hi guys,
I am using FME2019 and received this in the log:
Starting translation...
Undefined macro `ChangeDetector_OUTPUT_UNCHANGED_MACRO' dereferenced in file `C:\\temp\\wb-xlate-1538456617178_5428'
Program Terminating
Translation FAILED.
I can run a Matcher transformer with the same inputs and outputs but when I use the ChangeDetector transformer on the same inputs and outputs the error comes.
Any ideas on what the issue might be?
Cheers, Dave.
Best answer by fmelizard
Please do send the workspace and log (so we know the build #) in via https://www.safe.com/support/report-a-problem/ -- this is a defect and we'd love to squash it.
  • October 3, 2018
FME 2019 is beta version still in the developing stage. If you find an issue in the beta, please report it to Safe support directly: Report a Problem
"Please note that the betas of FME 2019.0 are not considered production safe. They are still undergoing development and there may be significant changes in terms of appearance and usability between beta builds. If you have any concerns or specific questions, please contact our support team." -- FME 2019.0 Betas
fmelizard
Forum|alt.badge.img+19
  • October 4, 2018
daveapegg
  • October 5, 2018
Hi Dale,
The build # is 19099
daveapegg
  • October 5, 2018
I have found that if you connect all of the outputs it runs without issue...initially I didn't want an output of the unchanged data so I left it disconnected.
daveapegg
  • October 5, 2018
Hi Dale,
The build # is 19099 I have found that if you connect all of the outputs it runs without issue...initially I didn't want an output of the unchanged data so I left it disconnected.
bo
Forum|alt.badge.img+10
  • November 17, 2019
I just ran into the same issue on Build 19617 - WIND 64, by pressing "F5 or Shift F5" with or without caching on:
    Command-line to run this workspace:
        "C:\Program Files\FME2019\fme.exe" I:\Data\TableauVisualization\FMEConversion\PRODUCTION\General\LRS_QCER1.fmw
              --p_RouteID_Pattern "%U 060 %"
              --pPrecision "3"
no
Undefined macro `pTheme' dereferenced in file `I:\Data\TableauVisualization\FMEConversion\PRODUCTION\General\wb-xlate-1574016595228_15588'
Program TerminatingTranslation
FAILED.
What is more interesting is that I CAN turn on caching and click the last cache play button to run the entire workspace without issue!
