FME 2017.1 password in clear
  • Jul 13, 2018 7:00 AM UTC
  • 148 views
HI guys,
I have a question, in FME 2017.1 when we execute a command line with the SystemCaller, the command is prompt in the log and the password is in clear .... Do you have any tips to fixe it ? (I was thinking to rewrite the log to erase or hide it) .
The passwords are from private parameters and contains the word "password" inside.
Best answer by takashi
Indeed not good. A workaround I can think of is, stop logging before and re-start logging after, using two PythonCallers.
PythonCaller before SystemCaller: Stop logging
import fmeobjects
def setLogSilent(feature):
    fmeobjects.FMELogFile().silent(True)
PythonCaller after SystemCaller: Re-start logging
import fmeobjects
def unsetLogSilent(feature):
    fmeobjects.FMELogFile().silent(False)
oscard
Forum|alt.badge.img+23
  • Jul 13, 2018 8:24 AM UTC
Are those private parameters of the type "Password"?
  • Jul 13, 2018 8:27 AM UTC
import fmeobjects
import fmeobjects
Yes it's the type password
