Find the next closest date between 2 attributes
ngstoke
I have a list of attributes that have starting and completion dates listed for different teams.
After sorting the starting date column I'm trying to use the first attributes completion date to find the next attribute in the list that has the next closest starting date, then calculate the difference in days.
Below is a sample of my dataset.
So far I've been unable to find a way to automate this process in my workflow.
Any suggestions are much appreciated.
Best answer by takashi
Hi @ngstoke, if I understand your intention correctly, this workflow could work.
Note: I created this workflow with FME 20170. In the latest FME release version 2017.1, the DateFormatter has been upgraded to the DateTimeConverter.
Is this your desired result?
danilo_fme
Forum|alt.badge.img+43
  • August 19, 2017
hi @ngstoke has a custom transgormer very powerful to calculate the difference and find the next closest dates
https://hub.safe.com/transformers/datedifferencecalculator
Thanks,
Danilo
ngstoke
  • August 19, 2017
Thanks,
Danilo
Hi @danilo_inovacao I've tried using this transformer before but I can't get it to find the next start date that is nearest to its completion date for the calculation.
For the list of completion dates I need it to determine what well has the next closest start date.
So the next well with the closest start date after Well 1's Completion date is Well 2 with a 10/26 start date.
I can get the transformer to calculate the different for each row but I'm having trouble getting it to look for the closest start date in relation to all the other wells in the list, not between its own start and completion dates.
I hope that makes better sence.
Hi @ngstoke
is there a chance that Well(n) START_DTE will not be the closest START_DTE after Well(n-1) COMP_DTE? Can it happen to be before the Well(n-1) COMP_DTE? Are you looking for the START_DTE that is after COMP_DTE?
You will definitely find new FME 2017 datetime functionality very helpful. I also think you might need AttributeCreator with conditional values with adjacent features - the AttributeCreator at its best :)
Please share a small data sample here if you have one - it will help us brainstorming.
  • August 19, 2017
  • August 21, 2017
The DateTimeCalculator in FME 2017.0+ can also be used effectively. If the date format in the source features was '%Y%m%d' originally, the DateFormatter (DateTimeConverter in FME 2017.1) would not be essential.
ngstoke
  • August 21, 2017
lenaatsafe wrote:
Hi @ngstoke
Hi @LenaAtSafe I am looking for a way to identify the next closest START_DTE that occurs after each wells COMP_DTE. The ideal output would be a sorted list that identifies from the oldest date to the most recent the order in which the wells were drilled (STE_DATE to COMP_DTE).
There will instances in the data where the next closest STE_DATE for Well(n) will not be Well(n-1).
Forum|alt.badge.img+32
  • August 21, 2017
I have used a spatial approach to solve this sort of issue before
Convert the dates to seconds and use these to create boxes, then find the 2 nearest neighbours, and discard the one that is earlier to find the nearest start date
ngstoke
  • August 21, 2017
Thank you @takashi ! This is what I was trying to accomplish. I appreciate the detailed example.
  • August 22, 2017
Good to hear my example helped you.
If you are familiar with SQL, the InlineQuerier could also be a good solution.
InlineQuerier | SQL Query Example:
select
    a.WELL_NUM,
    a.START_DTE,
    a.COMP_DTE,
    b.WELL_NUM as NEXT_WELL_NUM,
    b.START_DTE as NEXT_START_DTE,
    b.COMP_DTE as NEXT_COMP_DTE,
    (strftime('%s', b.START_DTE) - strftime('%s', a.COMP_DTE))/86400 as _diff
from well as a cross join well as b on a.COMP_DTE <= b.START_DTE
inner join (
    select
        a.WELL_NUM,
        min(b.START_DTE) as START_DTE
    group by a.WELL_NUM
) as c on c.WELL_NUM = a.WELL_NUM and c.START_DTE = b.START_DTE
order by a.WELL_NUM
  • August 22, 2017
I'm interested in the capability of XQuery expressions to process features in conjunction with FME transformers. This is an experimental solution with XQuery.
XMLTemplater | Template (XQuery expression):
<result>{
    let $wells := {
        let $sd := fme:get-list-attribute("_list{}.START_DTE")
        let $cd := fme:get-list-attribute("_list{}.COMP_DTE")
        for $n at $i in fme:get-list-attribute("_list{}.WELL_NUM")
        let $w := <w n="{$n}" sd="{$sd[$i]}" cd="{$cd[$i]}"/>
        order by xs:date($w/@sd) ascending
        return $w
    for $a at $i in $wells
    let $b := fn:subsequence($wells$i + 1)[xs:date($a/@cd) <= xs:date(@sd)][1]
    where fn:exists($b)
    return
    <well>
        <WELL_NUM>{xs:integer($a/@n)}</WELL_NUM>
        <START_DTE>{xs:date($a/@sd)}</START_DTE>
        <COMP_DTE>{xs:date($a/@cd)}</COMP_DTE>
        <NEXT_WELL_NUM>{xs:integer($b/@n)}</NEXT_WELL_NUM>
        <NEXT_START_DTE>{xs:date($b/@sd)}</NEXT_START_DTE>
        <NEXT_COMP_DTE>{xs:date($b/@cd)}</NEXT_COMP_DTE>
        <_diff>{fn:days-from-duration(xs:date($b/@sd) - xs:date($a/@cd))}</_diff>
    </well>
}</result>
