find intersection between lines and areas
  • Feb 22, 2020 4:54 PM UTC
  • 231 views
soly
Forum|alt.badge.img+3
i have many lines with diferent id and also Lines with many segments connected together between two area and i have 5 area with different id and different lines intersected with the same area and another lines intersected with another area and so on .some and i have the coordinate of points x,y that refer to the location of point intersected lines with in area ,i want to get the name of area that intersected with diff. lines ,and which lines intersected with this area and and i want to get also when line intersected not only with one ,may be 2 area so i want to know the id of this line and the name of two area that it intersected with .
FME 2018
Does spatial relator the transformer that i want or which transformers should i use,i am new in map and iam new in work on map and i am still reading and learning about transformers
Forum|alt.badge.img+63
The SpatialRelator would be a good starting point, yes.
soly
  • Feb 23, 2020 12:10 AM UTC
Thanks,I started trying to build my workflow with it .
