Find gaps in polygon layer
  • Dec 9, 2017 3:09 PM UTC
  • 395 views
kumarkannan1980
Participant
I need to find the gaps between two polygons (not auto - correction). Kindly let me know which transformer I have to use?
Thanks in advance
Regards,
K.Jayakumar
danilo_fme
Forum|alt.badge.img+58
  • Dec 9, 2017 6:19 PM UTC
Hi @kumarkannan1980,
You can see this solution in this case created here: Find gaps in Polygons
Thanks,
Danilo
kumarkannan1980
Participant
I tried "Dissolver" ,"AreatoAreaoverlayer" to find gaps between polygons . It fails in some situation. The result is inconsistent. I tried "AreaAmalagamator" it is working fine but it is taking more time even for less volume of data. Any other method/transformer to find the gaps.
I noticed that Dissolver some times failed to dissolve if the gap of the polygon is more.
erik_jan
Forum|alt.badge.img+26
  • Jan 4, 2018 2:24 PM UTC
Create a bounding box (Creator or BoundingBoxAccumulator) for the complete area.
Then feed both the polygons and the box to the AreaonAreaOverlayer.
Use the Tester to test if _overlaps = 1, those are locations without a polygon (gaps).
