Find duplicates in xml doc and apply condition in it using XQuery
  • Sep 3, 2019 3:59 PM UTC
  • 341 views
I am trying to find duplicates in my xml data and from that I would like to apply condition.
here is my xml doc
<results>
    <book>
        <id>1</id> <status> published</status>
    </book>
    <book>
        <id>1</id> <status> not published</status>
    </book>
    <book>
        <id>2</id> <status> sold</status>
    </book>
</results>
From the above xml, I want to find book id where id's are repeated and the status is published then return
<book>  <id>1</id> <status> published</status> </book>
using XQuery  .
Could you please help me on this. Thanks in advance.
Best answer by takashi
Hi @vvoona, this is a possible expression, assuming that the variable $doc stores the source XML document.
for $id in distinct-values($doc//id/text())
where 1 < count($doc//id[text() = $id])
return $doc//book[data(id) = $id and normalize-space(data(status)) = 'published']
  • Sep 4, 2019 12:30 AM UTC
  • Sep 4, 2019 10:05 AM UTC
Hello @takashi , it worked for me, you saved my time. Thank you so much :)
