Find dead ends from association using attributes only
  • Jul 19, 2019 5:56 AM UTC
  • 104 views
Hi Experts,
I am working on FME 2019.0. I have to find the dead ends from a huge road network (without geometry). I have to take only associations into consideration.
There are two columns jun_id_to and jun_id_from for each road. The value that comes just once in jun_id_to or jun_to_from both would be the dead-ending road. A small illustration about how the road network would look like and the association table is below:
Road geometry:
Attributes:
I tried using StatisticalCalculator, but, I am not sure if it can tell the count of each character in both the columns. Also, FeatureMerger with jun_id_to and jun_id_from merge doesn't give the required output. I think Lists might work in this case but not sure how.
Any ideas?
Thanks.
oscard
Forum|alt.badge.img+23
  • Jul 19, 2019 6:28 AM UTC
There could be more elegant solutions, but here is mine:
xlsxr2none.fmw
  • Jul 19, 2019 6:36 AM UTC
This will find all the node IDs that only occur once:
See also template for FME 2019.1: dead_end_node.fmwt
  • Jul 19, 2019 9:48 AM UTC
Hi @dewan, alternatively, if you are familiar with SQL, the InlineQuerier can also be a choice.
SQL Query:
select node_id
from (
    select jun_id_from as node_id from Sheet1
    union all
    select jun_id_to from Sheet1
group by node_id having count(*) = 1
