Filters in Excel Sheet - how to create in FME Form?
  • February 12, 2024
  • 200 views
vxn43
Forum|alt.badge.img+18
I have a workspace that writes to a simple Excel sheet. The sheet has 3 columns: Report Name, Upload Date, and Upload Time.
In Excel you can set a Filter for each column allowing a user to filter the data in that column.
In Excel, I added a Filter to each column, but when I write to the sheet in FME Form, the Filters disappear. Is there a way to “keep” or “add” a Filter to each column in the sheet by tweaking a Writer parameter or is there another Transformer I need to add before the Writer? The screen capture below shows what I would like the sheet to look like:
Best answer by dustin
If you use the Template File parameter to point to the spreadsheet with the filters, it should retain the filters when it writes the data.
dustin
Forum|alt.badge.img+31
  • February 12, 2024
