Filtering Top Result
I am sure this is a really simple action, but I don't seem to be able to sort it out.
I'm needing to filter off the top result out of a sorter in an attempt to make my workbench generic. I've run the data through a sorter, and the details I need are showing in line #1.
Cheers for any assistance provided.
Best answer by takashi
Hi @gavin_082, the Sampler transformer helps you.
  • Sampling Rate (N): 1
  • Sampling Type: First N Features
  • Randomize Sampling: No
The first feature will be output from the Sampled port, and others will be output from the NotSampled port.
  • October 24, 2017
  • October 24, 2017
Correction: The Sampling Type should be "First N Features". The answer has been updated.
  • October 24, 2017
Thank you very much. As I said, it was an easy task, I just couldn't get it
