FIltering out large number of Attribute values
  • Oct 17, 2017 4:11 PM UTC
  • 5 replies
  • 306 views
marsh007
Forum|alt.badge.img+11
Need to filter out the large list of Attribute values(Around random 10000 values) to be processed. Currently it is tedious using 'AttributeFilter' transformer as it needs all 10000 output ports to be connected to next transformer for further processing.
There should be other transformers for sure which I don't remember any. Please help.
-Thanks
danilo_fme
Forum|alt.badge.img+58
  • Oct 17, 2017 4:15 PM UTC
Hi @fmeuser_gc,
You can try to use the transformer AttributeRangeFilter.
The option Generate enable you set values Minimum and Maximum and the number of Ranges.
Thanks,
Danilo
marsh007
  • Oct 17, 2017 4:18 PM UTC
Hi @fmeuser_gc,
Thanks,
Danilo
This transformer might need all ranges. But I can't use range as all the values are random
erik_jan
Forum|alt.badge.img+26
  • Oct 17, 2017 4:20 PM UTC
I would list the values in an external source (database table, csv file, Excel file) and use the FeatureMerger to check if the values are available in the external source.
The database table would be my preference.
That allows adding values to the source without having to change the workspace.
marsh007
  • Oct 17, 2017 4:33 PM UTC
@erik_jan, this worked and is the best reply. You saved my time. Thanks.
joy
Forum|alt.badge.img+17
  • Feb 14, 2024 6:48 PM UTC
In addition to what @erik_jan said, instead of featuremerger, you could also use the databasejoiner.
Then you don't need another reader.
