Filtering features from CSV that are present in database
  • Jun 6, 2019 2:00 PM UTC
  • 7 replies
  • 348 views
p.jeremie
Helo,
I want to filter from a CSV file all the features that have an ID present in the database (unique ID as it is the table primary key).
For the moment I used a CSV reader to get my features from the CSV file and then used a Database joiner with join on the ID both in my table (primary key) and in the CSV. The cardinality is set to "1:1".
This way I get in the port the features with no match in the database table.
I'm not sure it is the fastest way (takes more than 50 sec to perform the join - ~400 000 lines in the table). Would it be more efficient to have all the ID's in a list and filter with this list ?
I am a little bit lost how to do it efficiently. Any idea would be appreciated.
itsmatt
Forum|alt.badge.img+48
  • Jun 7, 2019 8:13 AM UTC
It probably would be faster to have the list of ID's in a CSV file and then just use another CSV reader.
FME can read CSV super fast (like lightning fast) - and if you use the FeatureJoiner (not FeatureMerger) with the list of ID's and your original CSV you should see a very fast workflow. Just be sure you're using 2018+ to get the speed benefits (see this article on Bulk Mode: https://knowledge.safe.com/questions/49482/what-transformers-have-feature-table-technology-fo.html ).
If instead you want to keep using the DB joiner you could try using a Prefetch Query in the DatabaseJoiner
'SELECT id from <table>'
This could speed up your current process but I think having them in a list would be much faster if this doesn't create too much overhead. I'm no database pro so others might have better ideas.
Forum|alt.badge.img+54
  • Jun 7, 2019 8:28 AM UTC
Depends on the numbers involved and database set up, but it can often be quicker to write a temp table containing all the ids from the csv file, then an sqlexecutor to select all the records that don't appear in this temp table.
p.jeremie
  • Jun 7, 2019 8:52 AM UTC
Thanks, I forgot about the Prefetch query. It doesn't seems to accelerate the process though...
I'm on something else right now but I'll try with the ID's in a CSV + FeatureJoiner.
p.jeremie
  • Jun 7, 2019 8:56 AM UTC
@egomm : any hints on how to do this with FME (create the temp table and delete it after the SQLExecutor). I'm not sure how...
  • Jun 7, 2019 8:59 AM UTC
What flavour is your database?
p.jeremie
  • Jun 7, 2019 9:02 AM UTC
It's an Oracle DB.
p.jeremie
  • Jun 17, 2019 10:19 AM UTC
I ended up staying with the solution DatabaseJoiner + prefetch query. It is already pretty fast in fact... thanks for your help.
