I have a SHP file with geometry. It has an attribute called 'id_alt.' I would like to extract only the values of this attribute. Is there any way to convert these values into variables that I can use the value use with TESTER after UUIDGenerator to filter my data? Alternatively, what is the most efficient method to achieve this with FME
