Filter Point Cloud above/below a TIN surface
  • Jan 18, 2024 10:16 PM UTC
  • 165 views
mgg_beca
Forum|alt.badge.img+20
Hi there,
If I have been given a TIN and a point cloud, how can I find out which points are above the surface and which are below, without rasterizing the surface to retain maximum surface fidelity.
Thanks,
Marc
daveatsafe
Forum|alt.badge.img+24
  • Jan 22, 2024 9:23 PM UTC
Hi @mgg_beca​,
I think the simplest process would be to use an Extruder to extrude the TIN by a distance that will encompass the highest point in the point cloud. Then use a Clipper to clip the point cloud by the extruded TIN. Inside points will be above, while Outside points will be below.
If the TIN is a mesh geometry, you may need to use a GeometryCoercer to convert to a composite surface before extruding.
mgg_beca
  • Jan 22, 2024 9:26 PM UTC
Hi @mgg_beca​,
Hi @daveatsafe​ ,
I thought that might be the case, but figured I'd reach out and see if there was a more specific solution. I think there is definitely scope for a transformer to do this.
Regards,
Marc
james_c_452
Forum|alt.badge.img+10
  • Apr 15, 2024 1:01 AM UTC
I think I’ve done something similar in the past. I think I copied the z value to a new component (Zorig). Then ran through the surface draper. Then I took a difference of the old z and the new z. If its negative is below ground, positive above ground
