Hello Guys
we need to filter thousand of address into Odd and even number,
we are using the test filter, I think we should use the reg expression for the condition,
any idea how to write the expression
Thanks
Hello Guys
Thanks
This will match any odd number
^\d*[13579]$
But I'd probably just use a tester/testfilter
Actually it uses the same fmod function as ebygomm and someone kindly updated the transformers for 2019, so it should be good to use.
@boubcher FME functions will usually be faster than regex
^\d*[13579]$
@ebygomm
could please tell in test condition
the left value is the att to test
what is the condition?
and the right value ?
I know its basic thing but I am confused
Thanks
