Filter group attributes
  • Jun 16, 2020 7:55 AM UTC
  • 19 replies
  • 352 views
terezia86
Hello,
I need to filter the Attribute values into separate groups. See the image.
The values are always variable/different so I cannot use an AttributeFilter.
Any Idea?
Thanks
danilo_fme
Forum|alt.badge.img+58
  • Jun 16, 2020 10:58 AM UTC
Hi @terezia86
If you use the transformer Aggregator with list attributes enable?
Thanks,
Danilo
danilo_fme
  • Jun 16, 2020 11:13 AM UTC
Hi @terezia86
Thanks,
Danilo
Another alternative is the transformer DuplicateFilter.
terezia86
  • Jun 16, 2020 11:27 AM UTC
Hi @terezia86
Thanks,
Danilo
Hi @danilo_fme,
I have 94 features, each of these should be filtered into one of these (in this case) 6 groups (F-...).
The aggregator made me from these 94 feature only 6 features. See on the image.
I need to get the result like from AttributeFilter, (splitted feature into a different "groups") just cannot import the "possible attribute values" as they always different.
Forum|alt.badge.img+63
What do you want to do after filtering? A lot of transformers have a Group By option which is designed for exactly these kinds of circumstances.
terezia86
  • Jun 16, 2020 7:28 PM UTC
Hi @redgeographics,
After filtering, need to calculate which of these features in each “group“ is the longest one. The features are polylines, and for each feature have attribute with lenght value. (After that to the longest one add another paralel polyline.)
Forum|alt.badge.img+54
  • Jun 16, 2020 7:38 PM UTC
If you want to keep only the longest line in each group, if you sort by the length in descending order, then use a DuplicateFilter with the key attribute set to src you will keep just the longest line for each src value
terezia86
  • Jun 16, 2020 8:05 PM UTC
I need to keep all of the features, not only the longest one.
  • Jun 16, 2020 8:18 PM UTC
Then I'm not sure what you are trying to achieve. But dynamic filtering is not going to be the answer.
Either you want to do something different to each group, in which case you need to know the groups values so you know what process to apply to each.
Or you want to do the same thing to each group, in which case it's likely that this can be achieved with a Group By option as mentioned by @redgeographics
terezia86
  • Jun 17, 2020 5:51 AM UTC
Hi @ebygomm,
thanks for answer
ok, let me explain more.
I have these 94 features-lines (in this case), each of this lines belongs to the one of these 6 groups/src (in this case). The cases are always different, thats why it has to be flexible! After filtering the features into the groups, need to find out which of these featues in each group is longer than 1 km. Only the longest one, even there will be more than just 1 which is longer than 1 km, becommes 2 extra polylines XY. All other polylines become only 1 extra Polyline X. And this must be done for all groups. So I need to keep all features.
Hope it helped
pratap
Forum|alt.badge.img+12
  • Jun 17, 2020 6:06 AM UTC
If your values are dynamic then you can use InlineQuerier too. Example of workbench is provided in another thread...
https://knowledge.safe.com/questions/115062/splitting-single-input-into-multiple-outputs-for-p.html?childToView=115091#answer-115091
terezia86
  • Jun 17, 2020 7:48 AM UTC
Hi @pratap,
thanks for your comment.
I tried to use an InlineQuerier, but umfortunately it did not work. Happend nothing, the attributes were not sorted in groups. Maybe just wrong setting? How to achieve here the group settings?
Thank you
pratap
  • Jun 17, 2020 10:58 AM UTC
Hi @pratap,
Thank you
Hi @terezia86,
Your query says to pass all attributes as-is.
"Select distinct src, tgt from output" then you will get unique combination of src+tgt.
"Select distinct src from output" then you will get unique values of src
terezia86
  • Jun 17, 2020 11:37 AM UTC
Hi @terezia86,
Hi @pratap,
thanks, once more.
I do not know, maybe am missing something here?
I changed the setting as you wrote to only "Select " src" from output, but the result is the same, no groups, in fact here happend anything. Is this transformer really the right one to group the attributes?
pratap
  • Jun 17, 2020 12:02 PM UTC
Hi @pratap,
thanks, once more.
You have missed the word "distinct"
Attached sample for reference
17jun2020.fmw
Added other option as well
terezia86
  • Jun 17, 2020 12:08 PM UTC
17jun2020.fmw
all right! now I see what we have achieved :-)
But unfortunately, this is not what I need. I need all my features (94) to be filtered in 6 groups. To keep all the features.
Exactly the same what the AttributeFilter is doing, just I cannot define the "src" value before, because the value always different.
Thank you very much for your comments.
jdh
Forum|alt.badge.img+41
  • Jun 17, 2020 9:31 PM UTC
It would be helpful to share a workspace with your processing after the AttributeFilter (hard code it for now).
I suspect that @ebygomm's solution or something similar (sorter, sampler with group by) will be the way to go.
You say (per group) the longest polyline greater than 1km becomes two extra, but how is that accomplished?
pratap
  • Jun 18, 2020 5:16 AM UTC
Does this mean, you have dynamic values but data has to be split based on some attribute...
For understanding your question better. you want to use attributefilter with dynamic values/not predefined values. Am I right?
If the above explanation is correct then you can use aggregator with groupby option additionally you can use generate list option for retaining remaining attributes. with this all the similar group will make to one feature like multigeometry feature. Later you can use ListExploder...
terezia86
  • Jun 18, 2020 6:37 AM UTC
Hi @pratap,
yes, you understand it well. Thanks.
I tried it as you suggested.
Anyway I am not sure if this way is the correct way to acchieve what I need. I aggregated the features into the "groups" with aggregator (by using group by "src" and using generate List).
I´ve bekomme 6 "groups" as you can see on the pic2.
My next step should be: in each group, to work with the lenght of each feature. To find out which feature is longer than 1 km etc. In this case I cannot work with each feature, because as you wrote the "groups" are made of multigeometry feature..?
I need to have all features as they are, but in groups filtered...(something like fanout, but transformer, not writer)
After applying a ListExploder I get back all features, but unfortunattely as lenght Values were overwritten by the value from "group feature" . see the pic3.
pratap
  • Jun 18, 2020 7:16 AM UTC
Hi @pratap,
You have used only src attribute in lists... Use "all attributes" options
I have attached a sample with LEN attribute for review ...
18jun2020.fmw
