Filter data based on multiple columns
  • Nov 17, 2021 4:45 PM UTC
  • 313 views
As an example, in Excel you would use the filter function and select specific values from the drop down menu across multiple columns.
How in FME do you filter rows of data based on attributes held in multiple columns?
I've looked at the two SQL translators; SQLCreator and SQLExcuter but both need connecting directly to a database. In my case I need to use the transformer within my workflow.
Thanks.
Best answer by drc43
You can use a Tester transformer with an AND or OR (or other) logic on multiple rows in the transformer to 'test' multiple fields.
http://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/tester.htm
drc43
Forum|alt.badge.img+13
  • Nov 17, 2021 6:11 PM UTC
geomancer
Forum|alt.badge.img+71
  • Nov 18, 2021 8:12 AM UTC
Or if you absolutely want to use SQL, take a look at the InlineQuerier.
  • Nov 19, 2021 2:39 PM UTC
Thank you that's perfect.
I'll keep this in mind for the future!
