Fill values automatically
  • Apr 27, 2020 9:51 PM UTC
  • 14 replies
  • 228 views
mr_fme
Forum|alt.badge.img+9
hi,
I have an excel file, which has 3 fields: date, confirmed and country. But some data and confirmed values are without values. For those who are without values, I would like them to be filled out, considering the last value. In other words, the last data for a given country was 04/29 and the next data record for empty, the filling must be automatic for 04/30. The same thing should happen for "confirmed" if the last record is determined for 50 country and the next record is empty for that same country, the filled value must be 50, always the previous value.
thank´s
danilo_fme
Forum|alt.badge.img+58
  • Apr 27, 2020 9:54 PM UTC
Hello,
Please, could you share your data?
Thanks in Advance,
Danilo
mr_fme
  • Apr 27, 2020 10:20 PM UTC
sheet.xlsxFollows my excel file. Thank´s @danilo_fme
bwn
Forum|alt.badge.img+26
  • Apr 28, 2020 3:37 AM UTC
This can be done in an AttributeCreator by:
  • Turning On "Adjacent Feature Handling" Preceding Features = 1
  • Setting the value by Conditional Values. Eg. If NOT @Value(Confirmed) Attribute Has a Value Then Set Attribute Value = @Value(Confirmed[-1]).
This will set the value to the the preceding value (The [-1] is the relative index from the current Feature), where the Value is Missing or NULL.
Similar logic for the "Date" Attribute, except the Attribute is set by adding a Day to the previous Date by referencing Date[-1] in the same AttributeCreator and using the Date/Time FME functions such as @DateTimeAdd().
mr_fme
  • Apr 28, 2020 1:01 PM UTC
Thank´s @bwn
But unfortunately in the final result, the empty fields are using the confirmed values from the previous feature, regardless of the country. This resolution should be grouped by country. Example Canada cannot use the previous feature value if it is USA, the name of the country.
Forum|alt.badge.img+54
  • Apr 28, 2020 1:07 PM UTC
Thank´s @bwn
In which case you just need to sort by country then add an additional test to check if the country value is the same as the previous feature
mr_fme
  • Apr 28, 2020 1:41 PM UTC
could you explain it better? I´m new in FME
  • Apr 28, 2020 1:55 PM UTC
So a sorter prior to the attribute creator, then the attribute creator with a conditional statement as @bwn explained but as well as testing for if the attribute doesn't have a value, the test checks whether @Value(Country)=@Value(feature[-1].Country)
  • Apr 28, 2020 2:47 PM UTC
Regarding "Confirmed", a possible way is to use a global variable containing the value of "Country" within its name, in order to save and retrieve the last Confirmed value for each Country.
Be aware that you have to set Across Output Ports to the Preserve Feature Order parameter in the Tester if you need to preserve the order of input features in the subsequent process.
mr_fme
  • Apr 28, 2020 3:12 PM UTC
@ebygomm, unfortunately I was not successful
I have "confirmed" values not filled and the date field simply repeated. I also need to add an extra day on the previous date, if this field is empty.
Thank you so much
  • Apr 28, 2020 4:21 PM UTC
Thank you so much
You have the test condition incorrectly written for the Confirmed Attribute - you are testing @Value(Country) = @Value(feature[-1].Confirmed) which will never match.
For the date you need to change the attribute value to be @DateTimeAdd(@Value(feature[-1].Date),P1D)
This will add one day on to the previous value
mr_fme
  • Apr 28, 2020 4:23 PM UTC
@takashi,
which version are you using? I still have problems see the images
Thank´s
  • Apr 28, 2020 4:51 PM UTC
Strange. I tested it with FME 2019.1.1, 2019.1.2, 2019.1.3.1, 2019.2.3.2, and 2020.0.1. What versions of FME are you using?
mr_fme
  • Apr 28, 2020 9:41 PM UTC
Thank´s you helped me a lot. Solve my problem
mr_fme
  • Apr 28, 2020 9:43 PM UTC
@takashi, thank´s, my FME 2020.0.1.
Now work, very good!
Thank´s
