Fill columns based on conditional values?
  • Oct 1, 2020 10:45 PM UTC
  • 178 views
ileung_cnw
Forum|alt.badge.img+4
Hello FME Community,
First time posting here! Hope to explain my problem better with screenshots of my current situation and what I hope to achieve.
fme_start
I have 3 empty columns I like to them to be filled with values from Status_Percentage.sum based on the feature's status (e.g. Built, Intended, Interim).
The result should look like this:
excel_screenshot3
The image shows values from Status_Percentage.sum filled to each empty columns based on the feature's status.
I've looked into AttributeManager and conditional values but not getting what I want. I've been advised to look at VariableSetter and VariableRetriever but am not familiar with the transformers.
Any help is appreciated! Thanks in advance.
Best answer by samisnunu
I created your mock data to test how that could be done in a simpler and uncomplicated way
simply use the FeatureMerger with the Join on parameter set to: 1-1FME_populate_attributes
jonas_nelson
Forum|alt.badge.img+34
Is this Excel data? There was a recent webinar on handling Excel data, check it out (Go to the Knowledge Base) if you haven't already. You might find a solution there.
samisnunu
Forum|alt.badge.img+15
  • Oct 2, 2020 4:53 PM UTC
ileung_cnw
  • Oct 2, 2020 5:47 PM UTC
Thanks for looking into this! This solved my problem! I was looking at using FeatureMerger but couldn't figure it out until now by using AttributeFilters and enabling "Process Duplicate Suppliers". 😀
ileung_cnw
  • Oct 2, 2020 5:48 PM UTC
No this is a table from a file gdb. Thanks for the info!
