File Copy Writer - Copy a DWG file from one folder to another
  • Dec 15, 2023 5:42 PM UTC
  • 205 views
boomer87
Forum|alt.badge.img+5
This is a silly question, but I can't seem to use the File Copy writer to copy a DWG file to another folder properly. The transformation seems to run with no issues, but when I check the output folder I specified, the DWG file is not there.
In the Reader, I chose to merge it as a single merged type, as the DWG has about 30+ individual layers in it.
Is there a method to ensure I just copy over the whole DWG file into another folder? I don't want to move the original file, simply make a copy of it to another folder.
Thanks everyone
pimc
Forum|alt.badge.img+8
  • Dec 18, 2023 7:33 AM UTC
Hi there!
It sounds like you're using a DWG reader in your Workspace. However, the Filecopy writer expects a path with the location of the source file (one feature with the path is enough to copy the entire file to your configured destination).
A common setup is a Directory and File Pathnames [PATH] reader, which reads files from a location on your machine and stores the path in an attribute. You can then use this attribute as a source for your Filecopy Writer.
To summarize:
  • The File Copy writer is configured with the destination where you want to copy your file(s) to
  • The File Copy writer expects an attribute containing the original location of your file(s) to copy from (filecopy_source_dataset)
  • The Directory and File Pathnames [PATH] reader can be used to easily extract file paths and use them as input for your File Copy Writer
Hope this helps and good luck!
Pim
boomer87
  • Dec 18, 2023 11:44 PM UTC
Hi @pimc​ !
Thanks so much for the resposne! I'll fiddle around with the Directory and File Pathnames reader and see if that can resolve the issue! Thanks again!
