FeatureWriter error / Field type of number
  • April 17, 2024
  • 96 views
galigis
Forum|alt.badge.img+19
Hi All,
I’m getting the following error in the FeatureWriter transformer:
A field type of 'number(20,version;1;cell_border_formatting;NO;text_alignment;NO;cell_protection;NO)' was specified, which is not valid. Please check the documentation on the Reader/Writer for information on valid field types
...the normal GDB writer works perfectly fine with the same data...I had a look into the field types but couldn’t find the error,
Any ideas?
evieatsafe
  • April 18, 2024
Hi @galigis could you provide additional information such as:
  • what version of FME are you using?
  • could you provide a screenshot of your configuration within the FeatureWriter?
  • Is this being written to an existing GDB or a new one?
If this is urgent to you, I would suggest submitting a support case with us.
