Features extracted from IFC with no identified CRS need to be exported to OBJ - but the output appears stretched along the Z axis
  • Sep 10, 2020 10:44 AM UTC
  • 56 views
I'm trying to convert various features of an IFC file to OBJ files. I'm able to do the entire transformation up to the point where I save the OBJ files, but it seems that the coordinates are in a projected CRS, evident from the very large X and Y coordinates. I have tried using a CommonLocalReprojector transformer (with a FeatureHolder just before it to make sure the transformation is done relative to the entire feature set):
But the models appear stretched when I view them in Blender. Quite drastically. You can see that the doors are much taller than they should be, based on their width to height ratio:
The only geographic information I really have from this file is RefLongitude and RefLatitude. But like I said, the coordinates themselves appear as large X and Y values, at least after being read from FME
Does anyone have any idea on how I can fix this?
sigtill
Forum|alt.badge.img+25
  • Sep 14, 2020 11:06 AM UTC
How does the data look like in FME Data Inspector
