FeatureReader fails to recognise Attributes in CSV file
  • Jul 3, 2024 4:38 AM UTC
  • 203 views
nicholas
Forum|alt.badge.img+14
FeatureReader does not recognise attributes
Hello all, I am having problems with a FeatureReader that does not recognize the attribute columns of a CSV file.
The background is, I regularly download the GNAF dataset from Geoscape Geocoded National Address File (G-NAF) | Datasets | data.gov.au - beta
The GNAF arrives as a zip file containing a large number of CSV files. I only need five of them.
I have built a Directory and File Pathnames Reader that returns all of the CSV files, which I then filter down to just the five that I want.
I am attempting (but failing) to build a FeatureReader that reads the CSV file.
I should point out that the CSV file is actually a pipe-separated-value file. The separator is a pipe “|” and the file extension is “.psv” But I have confirmed that a normal CSV reader does successfully read the psv file.
Now, the FeatureReader is successfully reading the correct number of features. And FME automatically recognises that two of the columns are LONGITUDE and LATITUDE and goes on to render a map of points. But when I view the Table it says <no schema>
Here is the parameters of a standard CSV Reader that works
And here is the Properties and Parameters of the FeatureReader that does not work
Properties
As far as I can tell, I have the same settings for both the FeatureReader and the Reader
I do not know what I am doing wrong
nielsgerrits
Forum|alt.badge.img+67
The attributes are there, but as the datasets are read at runtime via the path_windows attribute, the attributes are not known beforehand and therefore need to be exposed. This can be done using an AttributeExposer. If FeatureCaching is on, after you run the workspace up to the FeatureReader, simply connect an AttributeExposer to the FeatureReaders Generic outputport and choose import from feature cache.
