FeatureReader Excel keeps old Column Names
  • Jan 27, 2022 8:35 AM UTC
  • 126 views
Hello i have Columnname A and B.
I read the Excelfile with a FeatureReader. Get Columns A and B.
Now i close FME. Rename Columname A to C in the Excelfile.
Open FME. Read the Excelfile. Get Columns A and B instead of C and B.
Why does FME cant see my renamed Column C and still sees Column A wich doesnt exist anymore?
Forum|alt.badge.img+63
Those kinds of changes will require you to redo the FeatureReader, there doesn't seem to be a way to update it (like you would have with a regular reader). Also any subsequent transformers that rely on the column that you have renamed will need to be updated.
  • Jan 27, 2022 10:49 AM UTC
If i have 2 Excel Files in a directory.
Excel File 1 has the following columns:
A B
Excel File 2 is the same Excel but the renamed column A so:
C B
If i have a directory and filepathnames reader and read both path_windows and then i use a testfilter to only get Excel File 1.
Then i use the FeatureReader with the path_windows Attribute as Source.
As "to reading Featuretypes" i set it to a whitespace. So in the cache i get "no shema" but the attributes are hidden. A and B. so i could expose them.
If i change my testfilter to get Excel File 2 and read it with the FeatureReader then i get "no shema" again and now there are C and B hidden.
So is there a way to make all hidden columns visible without specifically naming the columns that needs to get visible?
A B
C B
You'd want to look into a dynamic workflow but you still would have to know what the attributes are called if you want to do something with them.
There's a section in the 2019 Advanced training material about Dynamic translations that could be helpful.
