FeatureMerger error after upgrade to FME 2018 : 'REJECT_INVALID_GEOM YES CLEANING_TOLERANCE NONE'
  • May 9, 2018 8:57 AM UTC
  • 5 replies
  • 74 views
Hello,
After upgrading to FME2018, I have this strange error on featureMerger:
2018-05-09 07:00:21| 2.3| 0.1|ERROR |FeatureMerger(ReferenceFactory): The clause 'REJECT_INVALID_GEOM YES CLEANING_TOLERANCE NONE' within 'FACTORY_DEF {*} ReferenceFactory FACTORY_NAME FeatureMerger INPUT REFERENCER FEATURE_TYPE StringReplacer_OUTPUT INPUT REFERENCEE FEATURE_TYPE StringReplacer_2_OUTPUT REFERENCE_INFO ATTRIBUTES REFERENCE_TABLE @EvaluateExpression(FDIV,STRING_ENCODED,<at>Value<openparen>TEXT<closeparen>,FeatureMerger) @EvaluateExpression(FDIV,STRING_ENCODED,<at>Value<openparen>TEXT<closeparen>,FeatureMerger) AUTO ATTR_ACCUM_MODE HANDLE_CONFLICT ATTR_CONFLICT_RES REQUESTOR_IF_CONFLICT IGNORE_NULLS No HANDLE_NULL_MISSING_KEYS_LIKE_FME2013 No LIST_ATTRS_TO_INCLUDE <Unused> LIST_ATTRS_TO_INCLUDE_MODE <Unused> MERGE_ATTRIBUTES Yes MANAGE_FME_TYPE Yes MODE COMPLETE PROCESS_DUPLICATE_REFERENCEES No REFERENCEES_FIRST No REJECT_INVALID_GEOM YES CLEANING_TOLERANCE NONE OUTPUT COMPLETE FEATURE_TYPE FeatureMerger_MERGED' is incorrect. The clause must look like: REJECT_INVALID_GEOM [(yes|no)]
2018-05-09 07:00:21| 2.3| 0.0|INFORM|Closing the Geodatabase reader
2018-05-09 07:00:21| 2.3| 0.0|ERROR |The clause 'REJECT_INVALID_GEOM YES CLEANING_TOLERANCE NONE' within 'FACTORY_DEF {*} ReferenceFactory FACTORY_NAME FeatureMerger INPUT REFERENCER FEATURE_TYPE StringReplacer_OUTPUT INPUT REFERENCEE FEATURE_TYPE StringReplacer_2_OUTPUT REFERENCE_INFO ATTRIBUTES REFERENCE_TABLE @EvaluateExpression(FDIV,STRING_ENCODED,<at>Value<openparen>TEXT<closeparen>,FeatureMerger) @EvaluateExpression(FDIV,STRING_ENCODED,<at>Value<openparen>TEXT<closeparen>,FeatureMerger) AUTO ATTR_ACCUM_MODE HANDLE_CONFLICT ATTR_CONFLICT_RES REQUESTOR_IF_CONFLICT IGNORE_NULLS No HANDLE_NULL_MISSING_KEYS_LIKE_FME2013 No LIST_ATTRS_TO_INCLUDE <Unused> LIST_ATTRS_TO_INCLUDE_MODE <Unused> MERGE_ATTRIBUTES Yes MANAGE_FME_TYPE Yes MODE COMPLETE PROCESS_DUPLICATE_REFERENCEES No REFERENCEES_FIRST No REJECT_INVALID_GEOM YES CLEANING_TOLERANCE NONE OUTPUT COMPLETE FEATURE_TYPE FeatureMerger_MERGED' is incorrect. The clause must look like: REJECT_INVALID_GEOM [(yes|no)]
2
Any idea ?
Thanks !
fmelizard
Forum|alt.badge.img+22
  • May 9, 2018 8:12 PM UTC
Hi @biboba, are you able to upload your workspace or a picture of it? It would be helpful to see what's going on and what is entering the FeatureMerger when you see this error.
warren156
  • Aug 9, 2018 12:59 PM UTC
Hi @TiaAtSafe
Any chance you found a solution to this? I had my workflow throw this error recently and I can't seem to figure out why.
Warren
warren156
  • Aug 9, 2018 1:02 PM UTC
Hi @TiaAtSafe
Warren
I'll add that this workbench runs just fine when initiated from within FME but if I call it from a bat file then it produces this error.
  • Aug 9, 2018 1:06 PM UTC
Hi @TiaAtSafe
Warren
On my side, I had this error after saving a FME 2016 workbench with FME2018 without having made any modification.
Then running it with FME2016 raised the error.
Maybe the default FME that is launched by the bat file is not the 2018 ?
Hope this can help,
Nicolas
warren156
  • Aug 9, 2018 1:21 PM UTC
Hope this can help,
Nicolas
Aha! Thanks Nicolas @biboba,
I was opening the workbench with FME 2018, but my .bat file was calling a 2017 installed version. After correcting this my workbench ran without error. I appreciate the post! Warren
