FeatureJoiner failing
  • Sep 3, 2025 9:33 PM UTC
  • 183 views
tullus
Observer
Hi all,
I have two CSV files (A and B) that I've included using CSV readers, and I need to join them using a feature joiner on a specific column. CSV A contains numbers in all rows, whereas CSV B has numerous <Null> cells in the column. When I run the feature joiner it fails. I already tried:
  • Changing both attribute types to number
  • I included attribute managers before each CSV to include letters with the numbers of each CSV file to force matching as text
Does anyone have any suggestions?Β
Many thanks.
Β
Β
Best answer by alexbiz
Maybe the best strategy would be to filter those features without values (using a simple tester) before your FeatureJoiner
  • Sep 3, 2025 11:08 PM UTC
Hi ​@tullusΒ ,
FeatureJoiner outputs features through the <Rejected> port, if a Join On attribute was <null>. It's an intentional behavior, see also the Help on FeatureJoiner.
Configuration / Output Ports / <Rejected>
Invalid features from any input port. Features will be rejected if a Join On value is missing or null.
Β
If you want to continueΒ the translation when a feature was rejected, try connecting a transformer e.g. Logger or Junction to the <Rejected> port.
alexbiz
Forum|alt.badge.img+35
  • Sep 4, 2025 6:12 AM UTC
tullus
Observer
  • Observer
  • Sep 4, 2025 1:40 PM UTC
Thanks both. I filtered the features using the tester and then the feature joiner worked. Then I linked the other part of the tester to an Attribute Manager together with the feature joiner result. Kind of bypassed the <null> cells and them put them together in the process using the attribute manager.Β Worked well.
