Feature layer not showing in map from HtmlReportGenerator
  • Nov 3, 2025 9:48 AM UTC
  • 180 views
hannahwh05
Forum|alt.badge.img+10
Hi FMEers,
I’m trying to create a basic map using the HtmlReportGenerator. I’ve added 2 polygon hosted feature layers from our ArcGIS Enterprise Portal, that are comma separated in that URL field.
They are shared with groups that I am a member of so I have access to view them.
When I send it through to an html writer, the output map is blank. I wasn’t sure if that was because it is offline so I also published to FME Flow but it’s still blank:
I also tried with a layer shared to public from our portal with the same results.
Is there something I’m missing from the docs?
s.jager
Forum|alt.badge.img+27
  • Nov 13, 2025 9:10 AM UTC
Not a 100% sure, but this could be due to a CORS-error. Press F12 in your browser, reload the page, and check the network requests and their responses, and the console.
I would assume ArcGis Online would have Access-Control-Allow-Origin set to *, but you know about assumptions...
desiree_at_safe
Forum|alt.badge.img+25
Hi ​@hannahwh05! Have you tried referencing the layer itself?
I got it to work for myself by grabbing the URL from the feature service layer.
You’ll know it’s the right one if there’s an extra /0 at the end of the URL
You also might need to share the feature layer publicly
And send some geometry in to ensure the layer is zoomed to the right location. In my case, I created a local point with the Creator transformer.
Let me know if that helps! 😊
hannahwh05
  • Nov 14, 2025 11:18 AM UTC
Hi ​@desiree_at_safe this is exactly what I did and it gave me the blank output unfortunately
desiree_at_safe
Ah, I see. If you can, please  submit a ticket  so that our team can look into this further!
When submitting your ticket, I’d include (if available):
- Details about the environment used (e.g. platform and OS version, FME Flow deployment, any other dependencies, etc.)
- Any relevant log files (e.g. translation logs, job logs, fmeserver.log, etc.)
- Any relevant screenshots (e.g. errors, configurations, etc.)
- The workspace (or sample workspace) that you are encountering issues with. If, possible please send this as a template (.fmwt).
