Feature Count Problem
  • Nov 17, 2017 12:21 PM UTC
  • 6 replies
  • 148 views
I want feature count in a variable, I am using statistic calculator for this purpose but it ask me for attribute to analyze but i want count for all features.
I guess the below links are explaining my requirement.
https://knowledge.safe.com/idea/45903/add-a-count-attribute-to-the-featureholder.html
https://knowledge.safe.com/idea/48591/save-feature-count.html
Regards,
Dheeraj
Best answer by mark2atsafe
Use the FeatureCounter transformer from the FME Hub
Forum|alt.badge.img+54
  • Nov 17, 2017 12:24 PM UTC
Just use any attribute in the attribute to analyse, the count will still count all features
erik_jan
Forum|alt.badge.img+26
  • Nov 17, 2017 2:37 PM UTC
If you could use a FeatureWriter instead of the Writer, you could use the information in the Summary to get the feature count (per writer feature type) without using additional transformers.
mark2atsafe
Forum|alt.badge.img+59
  • Nov 17, 2017 4:52 PM UTC
  • Nov 17, 2017 6:11 PM UTC
Thanks @Mark2AtSafe
It works
darkspatiallord
Forum|alt.badge.img+8
Hey Mark
The domain setting used to be in the Counter but this was removed. Maybe we need a domain counter
mark2atsafe
Hey Mark
I think that's now just the Counter Name parameter. You can select an attribute there and it counts per unique value (like a group-by). But that still gives you 1,2,3,4,etc for each group.
The old way we used to get the result (I remember a specific training exercise) was to apply a Counter, sort by count (descending), and then take the first feature (which we might have had to do by creating a second count and testing for count2=0). Luckily things are way easier today!
