Feature Count Mismatch
After migrating data using FME from ArcGIS geodatbase 9.3.1 to ArcGIS geodatbase 10.2, it is found that most of the feature classes with less than 1000 records are not reflected in the geodatabase and also the feature class counts are rounded to the nearest 1000. (ie if feature count of a feature class in FME log is 23841, the corresponding feature count in geodatabase is 23000 and if the feature count is less than 1000 in FME log, there is no record for the corresponding feature class in geodatabase. Can some one help is solving this issue?
Login to the community
No account yet? Create an account
An FME Account is required to contribute
LoginEnter your E-mail address. We'll send you an e-mail with instructions to reset your password.
