Feature Compare Validation
  • Feb 21, 2018 6:35 PM UTC
  • 93 views
Good afternoon all!
I am having a problem with developing a QA/QC process for some CAD data. The ultimate objective is to compare the layers within the CAD files against base layer names located in a spreadsheet (i.e Elevation Contours, Houses, Lights, etc). I think the best way to do this is using Python. I have tried transformers but they only look at the data that is being run. I'm new to FME Python and I'm kinda lost so far. Any assistance would be great!
Thanks!
David
Best answer by danilo_fme
Hi @david_prosack88,
If you enable the attribute fme_basename from your CAD files and compare with attributes from Spreadsheet using the transformer FeatureMerger?
Thanks,
Danilo
danilo_fme
Forum|alt.badge.img+58
  • Feb 21, 2018 6:38 PM UTC
Thanks,
Danilo
Thanks,
Danilo
Thanks Danilo! I did try that however it does not list the layers that are missing. For example:
My spreadsheet has - Doors, Roof, Walls, and Windows. The CAD file given to me only has - Doors, Roof, and Windows. Walls are not in the CAD file. I would like that error to be called out.
When I use the FeatureMerger, it provides only the matching ones. Thanks for the quick response!
David
David
Actually you were right Danilo! I made some modifications to the comparison mode and it worked perfectly!
Thanks again!
danilo_fme
  • Feb 21, 2018 8:17 PM UTC
Thanks again!
I'm happy to help you @david_prosack88
