Fanning Out and Zipping Files Simultaneously
  • Jul 17, 2019 4:13 PM UTC
  • 8 replies
  • 258 views
mark2atsafe
Forum|alt.badge.img+59
Hey FME'ers. I just wanted to draw your attention to this useful piece of information I found.
See my tweet here: https://twitter.com/FMEEvangelist/status/1151516193263640577
Basically, when doing a Dataset Fanout you can set the folder to be a zip file when you write to it, or you can set the Fanout Expression to have a zip file extension, or you can use both!
I'm not sure when this got implemented. I think the first method has been around for a long time, but the other two might only be in 2019 or newer.
Hope you find this useful!
jdh
Forum|alt.badge.img+41
  • Jul 17, 2019 4:18 PM UTC
That's quite interesting. Now if only the DataDownload service could do the same...
mark2atsafe
  • Jul 17, 2019 4:30 PM UTC
Can you use this technique on a workspace that's used in Data Download? Hmmm. Apparently not. It doesn't seem to return any output. That's strange. I'll investigate.
jdh
  • Jul 17, 2019 4:37 PM UTC
Talk to Rahul about my experiments from the last two weeks, I don't think a case was ever created.
Lowdown is that any attempt to make dynamic internal folder names in the datadownload service zipfile with a regular file-based writer will end badly.
And yes I ended up with an empty zipfile a couple of times, I believe when the fanout was a straight attribute.
mark2atsafe
  • Jul 17, 2019 4:55 PM UTC
I'll check with Rahul and make sure something is filed with the devs.
  • Jul 17, 2019 5:09 PM UTC
Creating multiple zip files with Dataset Fanout has been implemented in 2016 ;-)
Idea: Allow Dataset Fanout to Create Multiple Zip Files
mark2atsafe
  • Jul 17, 2019 5:32 PM UTC
Ha! Was it really that long ago? I just found the enhancement request in our systems recently and it was still open. It was tested and found to work so the request was closed and I thought it would be a good idea to let everyone know! Oh well, I think it sometimes helps to mention these pieces of functionality that not everyone will know about.
Thanks for commenting!
jdh
  • Jul 17, 2019 5:41 PM UTC
I knew you could create multiple zipfiles, I had never attempted to create multiple zipfiles within another zip.
  • Jul 17, 2019 10:57 PM UTC
Hi @jdh, you are right. If you add the suffix ".zip" to both Destination Fanout Directory and Fanout Expression, the multiple zip files will be saved in a folder whose name is just suffixed by ".zip".
fanout-dataset-and-zip-archiving-1.fmw (FME 2019.1)
A possible way to archive multiplt zip files is to use a FeatureWriter and a File Copy writer.
fanout-dataset-and-zip-archiving-2.fmw (FME 2019.1)
