Failed to write raster data tile when writing to raster dataset error message
  • Nov 28, 2017 2:53 PM UTC
  • 200 views
I have a problem which seems to be quite random. I am creating a Raster from polyline feature class. I use SDE Feature Class reader, AttributeCreator/3DForcer/NumericRasterizer - and SDE Raster Dataset as writer.
Strangely - this arrangement works for some reader FCs - it fails for others with the message: Failed to write raster data tile when writing to raster dataset.
The readers (both successful and not) - are derived from the same large FC (same attributes) - so can't find any obvious relationship on this side... Any ideas what to look for? Thanks
Forum|alt.badge.img+63
Could you post the settings of the NumericRasterizer and the relevant part of the log file? That way we have a bit more information.
  • Nov 29, 2017 10:06 AM UTC
Hi @redgeographics,
here you arecapture3.pnglog.txt
Hi @redgeographics,
It looks like it's complaining about a non-geometry feature. Could you try using a GeometryFilter to make sure you're only processing line features in the NumericRasterizer?
