Failed to Evaluate TCL Expression - MicrosoftTeamsConnector Error
  • Oct 15, 2021 3:01 PM UTC
  • 160 views
I have a workbench that fetches data from an API and updates a Web App in ArcGIS. I am using the Teams Connector to publish update information to a relevant Teams channel. When running this workbench locally I receive no error and the message publishes successfully to Teams.
The Problem: After publishing the workbench to FME Server in Cloud, I am receiving a strange error which I cannot seem to find the solution to on any article. The error and workbench are shown below.
Error:
Workbench:
Workbenchimage
Looking forward to hearing any opinions.
itsmatt
Forum|alt.badge.img+48
  • Oct 16, 2021 9:22 PM UTC
The most likely issue is a difference in FME Version between desktop and Cloud so check that the versions are the same.
The next thing to look at is to make sure that the FME Package for the teams connector is up-to-date on fme cloud and fme desktop. You should be prompted when publishing about the package, make sure to publish the package you're using from desktop.
​If the versions are the same and you have the same package version on cloud and desktop then you should contact technical support.
